When adding a device in manage mode I receive the following warning:
"Devices added in management mode will have their configuration changed.
Aruba Technical Support recommends that you first add devices in monitor-only mode."
If I add the device in manage mode it will immediately have the template applied?
Is there any way to compare the current configuration to the template within airwave before pushing the template?
If I've already added the device in Monitor mode, changing it to Manage mode doesn't appear to apply the template. Is there any way to do so besides removing the device and then adding it again in Manage mode?
