Network Management
Pushing configs to multiple switches
  • 1.  Pushing configs to multiple switches
    Posted Jan 17, 2019 10:18 AM
    I currently have a network with 10 Aruba 2530 switches.  Each switch will have the same configuration with the exception of a different IP in the managment VLAN.
    I'm trying to find a way to:
    • Push a config to multiple switches at the same time
    • Run the command [show running-config] and return the output to a .txt or .config file so they can be backed up in a repository.
    Is this something that could be accomplished via SSH / Powershell scripting?
    edits:  spelling.
  • 2.  RE: Pushing configs to multiple switches
    Posted Jan 18, 2019 12:47 PM
    Asking the team.  I'm used to performing bulk operations through AirWave, but looks like you're trying to do this manually w/o NMS help.
  • 3.  RE: Pushing configs to multiple switches
    Posted Jan 23, 2019 02:57 PM
    Hello!
    Do you have experience with Python and/or REST API? That might be the best solution in regards to efficiency and overall ease. Also, where are you storing your configs? A server? Or on a local machine?
