Putting a router on a stick config on an IAP-205
  • 1.  Putting a router on a stick config on an IAP-205
    Posted Oct 29, 2015 10:31 AM
    I have been tasked with making the Arubas Cluster and setting one as the Gateway out to the internet for the Guest network So I need to beable to set the single ethernet interface to have two IPs on different vlans one for the internal network to maintain the cluster and the second Public IP to route the Guest SSID traffic. Any help would be appriciated.
  • 2.  RE: Putting a router on a stick config on an IAP-205
    Posted Nov 04, 2015 02:18 PM
    IAP questions go the Instant section.
    personally im not quite sure you can even do this. the Instant product is limited in some areas and putting IPs on interfaces is one of those things i believe. you have some basic routing, but policy routing like you ask, don't believe it is possible.
