I got this mismatches every day.
How can i fix this? Everything is working fine but it annoys me.
PVID mismatch on port 47(VID 410)with peer device port 484ae9-cb202e(VID unknown)
What device is connected on Port 47? if it is a managed Switch you should let Untagged VLAN IDs to match on both ports used on the uplink (follow this article and also this one as references).
On Port 47 is a Aruba AP-305 connected.
This thread should help you finding the most suitable solution to your issue (there are various ways to solve). Be sldo sure to work with the Aruba 2540 fully updated (ArubaOS-Switch should use latest YC.16.09.0004, YC.16.08.0006, YC.16.07.0006 or YC.16.06.0012 software release of each YC.16.x software branch whenever possible).
You can also disable send PVID vlan directly on Mobility Controller (on AP System Profile)
