PXE Boot?
  • 1.  PXE Boot?
    Posted Jan 10, 2012 01:56 PM
    Recently we upgraded from Cisco switches/router to Enterasys and changed our DHCP server to the Aruba 3400 controller.
    Previously, with the DHCP server on a Cisco router, I was able to PXE boot clients for cloning.  To do this, I just added
    next-server [IP of Fog cloning server]
    bootfile pxelinux.0
    to each DHCP Pool.
    Has anyone done this on an Aruba Controller?  I can find no documentation how to make this work again and could use some help.
    TIA!
    #3400
  • 2.  RE: PXE Boot?
    Posted Jan 10, 2012 02:34 PM
    It appears that these are DHCP options 66 and 67 (not 100% sure), see this link:
    http://www.iana.org/assignments/bootp-dhcp-parameters/bootp-dhcp-parameters.xml
    Assuming this is correct, you can set these options in the controller's DHCP server using the "option" command, for example:
    ip dhcp pool foo
    option 66 ip <server>
    option 67 text <filename>
    Hope that helps.
    Austin
  • 3.  RE: PXE Boot?
    Posted May 22, 2013 03:12 AM
    Hi
    Have you guys gotten this to work? I have a customer that this is not working as it should.
    The customer have lots of remote offices running RAP's today, after plugging a PXE computer in an ethernetport on the RAP, the client do get an IP and such.
    I have included the option 66 and 67 to the DHCP scope.
    At this point, the PXE client is not working, TFTP server timeout.
    Even tho we have plugged a windows computer into the same port with a tftp client on. Running a this client we are able to download the image.
    The funny thing is that when adding an ip helper-addres to the vlan, the PXE client is working all of a sudden.
    IP helper-address are forwarding a few UDP ports, so it might make sense that it wont forward broadcasts across L3 connections.
    The ip helper-address is pointing towards the TFTP (SCCM) server and not to a external DHCP server.
    The customer also have a 620 controller on a larger office, connected to the master via Internet. Local subnets/vlan's are routed thru the master-local IPsec tunnel. This works great for all other stuff, like AP's, RADIUS etc.
    Adding the IP helper-address on the 620 controllers VLAN should do the same trick if i'm not mistaken.
    But when we try to plug a computer doing PXE boot into a port on the 620, setting up a DHCP scope with the same options and also adding the ip helper-address, the bootp system will not work.
    Roar Fossen
