Hi all,
if you ever have the need to calculate the Message-Authenticator in an RADIUS packet by hand, I have made a small Python script that does so.
https://github.com/Linkk93/py-radius-helper To use it, you need to export the RADIUS part of the packet as bytes and then open the script in a bash / Powershell / etc
The script is very basic. The analyzed packet must already have a Message-Authenticator for it to work.
I hope you'll never need it ;)
Kind regards,
Bjarne
