Thought I'd share this. Disclaimer: I don't consider myself a "developer" (I'm a "network guy" by day). I'm sure there's plenty that could be done more efficiently, more elegant etc. Having said that - this works for me.
This is intended for Python 3. Above and beyond some of the typically included/built in modules, you will likely need to install colorama and pysnmp. I wrote this on a Debian machine, so the packages for this were python3-colorama and python3-pysnmp4 for me. This may differ on your distro / environment.
This uses good old insecure snmpv1/2c at the moment (I wrote this for my home network). I may try to add snmpv3 support at a later date.
Also I wrote this using my AP-515s running 8.6.x.x. I have no idea how it will behave / fall apart on other models / versions. Hopefully not too bad though...
Here is the help showing options:
usage: ap-client-list-aruba.py3 [-h] -vcs VCS -c COMMUNITY [-m MACFILE]
Connects to Aruba IAP VC(s), enumerates APs, and connected client info.
optional arguments:
-h, --help show this help message and exit
-vcs VCS Comma seperated list of VCs
-c COMMUNITY SNMP community
-m MACFILE Location of MAC address file (optional), defaults to /usr/local/etc/internal-macs.txt. Format is simply mac <tab> short_hostname. MAC format is xx:xx:xx:xx:xx:xx
Here is what the output looks like. The below has been sanitized. Also all the "UNKNOWN"s will go away and print pretty short names when you have your mac address file populated. Try to keep the names on the short side. I haven't tested the max length here in terms of formatting.
