Background:
Have a 10 Mb (7 bonded T1s) point to point circuit currently. Using VLAN tagging I'm using the same VLANs between the two sites. This works fine, no problems.
New Issue:
Upgrading to a 100 Mb point to point circuit. This new circuit will also allow for VLAN tagging but we are limited to 50 MAC addresses with the carrier. The 10 Mb circuit never had this limitation. What do you recommend as a method to continue using the same VLANs between the two sites but not exceed the 50 MAC limit to the carrier?
From my research I think I need some sort of layer 2 tunnel. The switching I have in place (5406zl and 2910al) doesn't support this. I was thinking I need to hang routers off the switching on both sides and do a L2TP tunnel. Would this "hide" the MAC addressing while still allowing me to extend the VLANs between the sites?
#q-in-q#qinq#l2tp
