QOS Aware Applications
  • 1.  QOS Aware Applications
    Posted Feb 01, 2019 02:29 PM
    We are starting to use Teams, Skype for business and Micollab - hosted phone system but as an app on laptops and pc's on wireless. As this is mixed in with all other traffic I am just wondering if someone can point me in the right direction for any wireless AP's and switches that would enable us to select QOS on the above traffic ?
    Any ideas ?
  • 2.  RE: QOS Aware Applications
    Posted Feb 01, 2019 03:12 PM
    It depends on the application.  I would start with the manufacturer of the software.
    The document for QOS for Microsoft Teams is here:  https://gallery.technet.microsoft.com/Implement-the-Quality-of-a11bf3b6
    Attachment(s)
  • 3.  RE: QOS Aware Applications
    Posted May 20, 2019 04:56 PM
    What about BYOD and Android users (not in domain for use GPO) that is 45% and 60% of users?
    Any updated doc (like VRDs) in AOS 8.X for "the new" Microsoft Teams?
    Best regards.
  • 4.  RE: QOS Aware Applications
    Posted Apr 16, 2020 02:55 AM
    As per the latest updates SkB is microsoft teams is it supports in UCC dashboard.
    Best Regards,
    Suresh
  • 5.  RE: QOS Aware Applications
    MVP EXPERT
    Posted Apr 16, 2020 03:48 AM
    Also just to add, if you are running Skype for Business in your environment. Cast your eye over the below resource, a worth while read!
    https://community.arubanetworks.com/t5/Validated-Reference-Design/Skype-for-Business-VRD/ta-p/508692
