Wired
QoS design for voice
  • 1.  QoS design for voice
    Posted May 17, 2023 01:00 AM
    Hi, i want to deploy QoS for voice on wireless controller. My question is, for the wired side, does the voice configuration needs to be applied on the switch that is connected to the controller/AP only, or does it need to be configured on the entire wired network?
    Other than that, is there any guide on how to configure QoS for voice on switch?
    Thank you.
    AA
  • 2.  RE: QoS design for voice
    Posted May 17, 2023 05:28 AM
    This video may be a good start.
  • 3.  RE: QoS design for voice
    Posted May 18, 2023 06:55 AM
    You'll need to trust the QoS tags (COS or DSCP) on the path from the endpoint across your wired network otherwise your tags will be removed on egress.
