I have 1 HP2910al-24G and 4 HP 2620's and I have the need to run QoS due to the Voice traffic on the network. All the 2620's uplink to the 2910.
I know there are a lot of QoS options but it's quite confusing. We have hard phones that connect to the switch (and the PC's connect to the phones). The phones tag Voice traffic into VLAN10.
So based on this, I setup VLAN 10 on all the switches and made it the Voice VLAN. Below is an excerpt from one of the 2620's.
I have a couple of questions.
1) If I set a VLAN to VOICE, I don't need to use any of the QoS options like dscp do I? Something tells me I don't need this but I can't seem to find much in the docs either way.
2) For the 2620's all ports should be UNTAGGED into Vlan1 and Tagged into VLAN10 correct?
I don't think I need any QoS settings if I use the VOICE vlan option yes?
Any insight would be most appreciated.
Thank you,
-Steve
qos dscp-map 100110 priority 7
vlan 1
name "DEFAULT_VLAN"
untagged 1-52
ip address 10.42.42.16 255.255.255.0
exit
vlan 10
name "Voice"
qos dscp 100110
tagged 1-52
voice
no ip address
exit
#DSCP#QOS#VLAN#Voice
