QoS over VPN
  • 1.  QoS over VPN
    Posted Nov 25, 2014 06:32 AM
    if you configure QoS on the Virtual Controller for the traffic generated by two roles (Role A and Role B - different DSCP tags) and you send this traffic through a VPN tunnel between the VC and the controller (located in the DMZ).
    Is it possible to mark the new IPsec header to differentiate traffic based on SSID (user role) and then apply qos policies before sending it through the MPLS to the controller?
    Borja
  • 2.  RE: QoS over VPN
    Posted Dec 01, 2014 06:24 AM
    Just in case anybody has the same question in the future.
    The QoS markings are copied to the outside of the tunnel so that they can be read in transit.
    Borja
