Quantity of AP can be supported by Instant AP
  • 1.  Quantity of AP can be supported by Instant AP
    Posted Aug 27, 2019 10:28 PM
    Hi community, how many AP can be controlled by 1 instant AP? Is the quantity of AP controlled by the instant AP same for all the Aruba AP model?
    Thank you!
  • 2.  RE: Quantity of AP can be supported by Instant AP
    Posted Aug 27, 2019 11:08 PM
    it is about 128x
  • 3.  RE: Quantity of AP can be supported by Instant AP
    Posted Aug 27, 2019 11:28 PM
    Hi Ariya, is there any Aruba document / datasheet stated the number 128 AP can be supported?
    Thank you.
  • 4.  RE: Quantity of AP can be supported by Instant AP
    Posted Aug 27, 2019 11:55 PM
    No there is no published document, but it is a guideline.
