Query for plugin updates shows XMLRPC error
  • 1.  Query for plugin updates shows XMLRPC error
    Posted Jan 15, 2013 05:47 AM
    Hi All,
    On a customers amigopod it's showing the followinf error when attempting to query for plugin updates..
    Plugin query list failed with XMLRPC error: XML response not found (HTTP code 417, content type text/html)
    A proxy server is required to get out to the internet but this has been entered on the Amigopod and the network tests pass.
    Just wondering if anyone else has seen this one before I log with TAC..
    Cheers
    James
  • 2.  RE: Query for plugin updates shows XMLRPC error
    Posted Jan 15, 2013 01:28 PM
    TAC is definitely the best route here.
  • 3.  RE: Query for plugin updates shows XMLRPC error
    Posted Jan 15, 2013 01:43 PM
    HTTP 417 is "Expectation failed".
    Is the proxy HTTP/1.1 compliant?
  • 4.  RE: Query for plugin updates shows XMLRPC error
    Posted Jan 16, 2013 04:25 AM
    Thanks guys.
    Yes, the proxy is HTTP/1.1 compliant.
    I'll speak with TAC.
  • 5.  RE: Query for plugin updates shows XMLRPC error
    Posted Mar 24, 2014 06:02 AM
    Im seeing a similar issue. Did you get a solution to this please ?
  • 6.  RE: Query for plugin updates shows XMLRPC error
    Posted Sep 15, 2014 08:10 AM
    Same problem, but no Proxy is used here. What was the problem solution?
