query on gre type on IAP
  • 1.  query on gre type on IAP
    Posted Jul 29, 2013 03:15 PM
    Hi Everyone,
    Can anyone tell me for what is the GRE type parameter is used in IAP?
    By default GRE type will be zero in IAP...what should be the correct value ? What if it has non zero value in GRE type? Can we have any value there?
    Please clarifye on my above queries as I am totally confused
    Thank you in advance..
  • 2.  RE: query on gre type on IAP
    Posted Jul 29, 2013 03:53 PM
    You should leave it as 0 , unless the endpoint device you are trying to build the GRE tunnel to requires an specific value
    Here one example from the IAP Guide :
    Aruba Instant 6.2.1.0-3.4 User Guide.pdf - Adobe Reader_2013-07-29_15-51-32.png
    This should help you :
    https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/What-are-the-GRE-type-ID-can-be-seen-between-Aruba-Access-Points-and-Controller
    This is on a controller:
    (controller) #show  ap debug datapath ap-name test-ap
    Datapath Parameters Table
    essid            encr-alg        client-vlan-id  tunnel-id  gre-type  deny-bcast  num-clients
    test-ssid          WPA2 8021X AES  702    0x122af    0x8240    disable          0
    Attachment(s)
  • 3.  RE: query on gre type on IAP
    Posted Jul 19, 2018 01:00 AM
    With control Plane security (CPSec) enabled, Aruba Aps connect to controllers with which protocol?
    1)ip sec
    2)HTTPS
    3)GRE
    4)PPTP
  • 4.  RE: query on gre type on IAP
  • 5.  RE: query on gre type on IAP
    Posted Jul 19, 2018 04:08 AM
    but which protocol use in network when enable CPsec ?
  • 6.  RE: query on gre type on IAP
    Posted Jul 24, 2018 03:00 PM
    The second entry in the linked google search has the answer.
