question about ap93/105 web/cli documentation
  • 1.  question about ap93/105 web/cli documentation
    Posted Sep 02, 2012 09:03 AM
    Hy all,
    I'm quite new to arubanetworks devices, i have bought 2 AP93 which are working quite right.
    i've started to take a closer loook to vlan dynamic assignment and the documentation i have is not related to the AP itself, but it always talks about the controller.
    I've downloaded arubaOS documentation, but it always refer to controller which i didn't bought,
    so i wanted to know where can i find specific APs OS documentation (if it exists) ?
    especially regarding vlan assignment attributes, which (as far as i have seen) are not documented in the arubaOS pdf .
    Thanks for your help,
    Xinity
  • 2.  RE: question about ap93/105 web/cli documentation
    Posted Sep 02, 2012 09:42 AM
    if your access points can run without a controller, they are IAPs, or Aruba Instant APs.  The documentation is here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Default.aspx?EntryId=5808
  • 3.  RE: question about ap93/105 web/cli documentation
    Posted Sep 02, 2012 12:15 PM
    thanks for your quick answer,
    it sems i failed in identifying IAPs from APs, mine are AP93 or so it is written on them.
    did i miss something ?
    Xinity
  • 4.  RE: question about ap93/105 web/cli documentation
    Posted Sep 02, 2012 12:22 PM
    Look on the BACK of your access point.  The only difference is that there will be a barcode that says IAP-105-XX or IP-93-xx.  Besides that, the software inside is different.
  • 5.  RE: question about ap93/105 web/cli documentation
    Posted Sep 03, 2012 04:31 AM
    Back online,
    I've check my APs, i have a a barcode which says: IAP-93
    i guess it is an IAP-93 which if i am correct is "more feature built" than an AP ?
    Xinity
  • 6.  RE: question about ap93/105 web/cli documentation
    Posted Sep 03, 2012 07:11 AM
    That means it has "Virtual Controller" technology.   It can also be converted to a regular AP.  More information is here:  http://www.arubanetworks.com/solutions/instant-wlan/
  • 7.  RE: question about ap93/105 web/cli documentation
    Posted Sep 03, 2012 07:18 AM
    thanks a lot,
    I will have more technical questions, but if not already answered here, i'll open nother topics.
    Xinity
  • 8.  RE: question about ap93/105 web/cli documentation
    Posted Sep 03, 2012 09:42 AM
    it seems, you are kind of stealing a thread my friend :)
    i would suggest you to open a new one, so informations won't be lost :)
    Xinity
  • 9.  RE: question about ap93/105 web/cli documentation
    Posted Sep 02, 2012 05:54 PM
    Thanks for your help, I'll take a look tomorrow
