Question about connecting to a Mesh Portal
  • 1.  Question about connecting to a Mesh Portal
    Posted Nov 16, 2011 04:35 PM
    I was under the impression that we could not connect a client(ie Laptop, phone, etc) to a mesh point or portal.  Then I was told at work that another engineer said it could be done.  I thought that the AP was either broadcasting as a normal thin AP or a Mesh AP(Used for backhaul).  Can someone please educate me?
  • 2.  RE: Question about connecting to a Mesh Portal
    Posted Nov 16, 2011 05:38 PM
    Client support on the same radio as the backhaul started being supported in AOS 3.4. It is also supported on InstantAPs.
    Jenga
  • 3.  RE: Question about connecting to a Mesh Portal
    Posted Nov 17, 2011 11:00 AM
    Ok, now that I know it can be done.  I have been searching the UG and can't find it.  How do I configure it?
  • 4.  RE: Question about connecting to a Mesh Portal
    Posted Nov 17, 2011 03:39 PM
    As long as the "RF Band" parameter on the Virtual AP is "ALL", it will broadcast and accept client on both bands of that mesh AP.
