Question about partitions and upgrading to 6.2
  • 1.  Question about partitions and upgrading to 6.2
    Posted Jun 10, 2013 04:47 PM
    This is probably a very simple question, I just want to ask it incase I'm incorrect. The guy before me that was handling upgrades to our Aruba controllers (both masters) always performed upgrades to the controller on one of the partitions. So currently both controllers have one partition at 6.1.3.4 and the second partition on 3.3.2.
    The release notes mention several times to only make a jump to 6.2 if you're on 6.1. Does this mean I won't be able to upgrade my second partition without brining it up to 6.1 first or can I make the jump to 6.2 since it's the second partition. I'm just unsure what part of the upgrade process requires 6.1.
    Thanks!
  • 2.  RE: Question about partitions and upgrading to 6.2
    Posted Jun 10, 2013 05:37 PM
    I dont think you understnading
    If you already got your Controller in 6.1.3.4 and thats your default partition, that that means that you are upgrading from 6.1.3.4 to 6.2.x
    It has nothing to do with the other partition with is not the defaut one.
    When you finish upgrading you will have one partition on 6.1.3.4 and the other on 6.2.x(Which will be the default one)
    I dont know if that is what you were asking for?
  • 3.  RE: Question about partitions and upgrading to 6.2
    MVP EXPERT
    Posted Jun 11, 2013 02:38 AM
    You need to upgrade the parition which isn't the **Default boot** parition to 6.2
    #show image version
    Partition               : 0:0 (/dev/hda1) **Default boot**
    Software Version        : ArubaOS 6.1.3.4 (Digitally Signed - Production Build)
    Build number            : 34587
    Label                   : 34587
    Built on                : Mon Jul 23 16:04:55 PDT 2012
    Partition               : 0:1 (/dev/hda2)
    Software Version        : ArubaOS 6.1.2.4 (Digitally Signed - Production Build)
    Build number            : 30768
    Label                   : 30768
    Built on                : Thu Oct 20 20:36:35 PDT 2011
    So in this example, I would upgrade parition 0:1 (/dev/hda2) and then reboot into this parition :
    #boot system partition 1
  • 4.  RE: Question about partitions and upgrading to 6.2
    Posted Jun 11, 2013 09:01 AM
    I think the question is if we have 2 partitions, one running 6.1.3.4 which is currently the default boot partition and another running 3.3.2, do we have to upgrade in steps or can it done all at once? See below for visual:
    3.3.2 -->3.4.5.1--->6.2
    or
    3.3.2---->6.2
    Again this would be on the non default boot partition. We are in the process of preparing to move to 6.2 since its GA release and I have had the same question.
  • 5.  RE: Question about partitions and upgrading to 6.2
    Posted Jun 11, 2013 09:06 AM
    Please read the 6.2.1.2 release notes, I have attached the document :
    Note: In order to upgrade 3200 these need a memory upgrade (not sure if this applies to you but just in case)
    Attachment(s)
  • 6.  RE: Question about partitions and upgrading to 6.2
    MVP EXPERT
    Posted Jun 11, 2013 09:08 AM
    You'll need to follow the path below :
    - For ArubaOS 3.x.versions earlier than ArubaOS 3.4.4.1, download the latest version of ArubaOS
    3.4.5.x.
    -  For ArubaOS RN-3.x or ArubaOS 5.0.x versions earlier than ArubaOS 5.0.3.1, download the latest
    version of ArubaOS 5.0.4.x.
    So yes,
  • 7.  RE: Question about partitions and upgrading to 6.2
    Posted Jun 11, 2013 02:32 PM
    Well it sounds like the the main partition is 6.1.x then I'm able to perform the upgrade to 6.2 by upgrading the 3.x partition, Correct?
  • 8.  RE: Question about partitions and upgrading to 6.2
    Posted Jun 12, 2013 08:56 AM
    Yes - if you are running 6.1 (in which case it should be the default partition) you would upgrade the other partition (3.x in your case). Then once the other partition is upgraded to 6.2 and once it's the default, a reboot will bring you to version 6.2
    Ian
  • 9.  RE: Question about partitions and upgrading to 6.2
    Posted Jun 17, 2013 03:30 AM
    OK, related question:
    I have primary partition 6.1 and secondary 3.3.
    Can I upgrade primary to 6.2 and then hardcopy it to second partition with command
    "copy system: partition 0 1"
    I'm concernd about partiotion resizing during 3.X->5.X>6.X upgrades.
    V.D.
