  • 1.  Question about the LEEF Clearpass message format
    Posted Sep 20, 2022 03:52 PM
    Can you explain what the field after version (3019 in the example) means? Identifies an event?
    LEEF:1.0|Aruba Networks|ClearPass|6.9.10.134806|3019|
    Regards
  • 2.  RE: Question about the LEEF Clearpass message format
    Posted Sep 21, 2022 09:36 AM
    It's the EventID. From this guide, the format of a LEEF message is:
    LEEF:Version|Vendor|Product|Version|EventID|​
    There could be a message for the EventID at the end, but you either removed it, or there is no message.
  • 3.  RE: Question about the LEEF Clearpass message format
    Posted Sep 21, 2022 10:25 AM
    Thanks.
    Yes, i removed the rest of the message. Where can we find a table with the correspondence?
    3019 description 3019
    3020 description 3020
  • 4.  RE: Question about the LEEF Clearpass message format
    Posted Sep 21, 2022 02:24 PM
    I'm not aware of such a table. LEEF is used to integrate with QRadar, and that has a translation table built in to parse the ClearPass messages.
    Most messages should be pretty obvious to understand, and there might be documentation available for SIEM vendors, but if you need that it would be best to work with Aruba Support or through your local Aruba Sales Team.
