question about triggers in Airwave
  • 1.  question about triggers in Airwave
    Posted Jun 30, 2015 12:44 PM
    Hi team,
    I would like setup a trigger including in its section "Notes" relevant data as: ip_address, username, hostname to give it more clarity to email alert. It's possible? It would me save time.
  • 2.  RE: question about triggers in Airwave
    Posted Jun 30, 2015 01:55 PM
    dont think this is possible but probably would make a great enhancement request.
  • 3.  RE: question about triggers in Airwave
    Posted Jun 30, 2015 06:50 PM
    OK, then it will posted on Ideas section of Aruba Support Center. Thank you for your answer.
    Regards
