Question: Clearpass and multiple untrusted domains supported? Problems?
  • 1.  Question: Clearpass and multiple untrusted domains supported? Problems?
    Posted Jul 18, 2019 07:04 AM
    Hi all,
    i have a customer who needs a NAC Solution and it's between Cisco ISE and Clearpass.
    I think Clearpass would be a perfect fit in this scenario because of many Aruba/HPE Switches and a planned Aruba WiFi Solution.
    But the customer said ISE is the only NAC Solution with support for mutiple untrusted domains, and we need that.
    But I'm not sure about this.
    I found information that multiple domains are possible with Clearpass but I have no personal experience.
    Does someone have experience with a setup like this? Is it possible with CLearpass or are there problems, caveats or unsupported features when using multiple domains that have no trust relation?
    Thank you very much,
    Best regards
  • 2.  RE: Question: Clearpass and multiple untrusted domains supported? Problems?
    Posted Jul 18, 2019 07:41 AM
    CPPM supports up to 64 untrusted domains.
