Wired Intelligent Edge
Question: Is there a way to control the Aruba S1500 Switch via SNMP?
  • 1.  Question: Is there a way to control the Aruba S1500 Switch via SNMP?
    Posted Feb 05, 2014 02:50 PM
    i wanted to control my S1500 Switch via SNMP but i only get this error message: SET failed.INFORMATION: No Access
    when i enter snmp-server ? on the cli there are only this options.
    community               set read-only community string
    context                 Create/Delete a context apart from default
    enable                  Enable SNMP Traps
    engine-id               Engine ID of SNMP server in HEX.
    group                   Define a User Security Model group
    host                    Specify host address to receive SNMP notifications.
    inform                  SNMP Inform parameters
    trap                    SNMP Trap parameters
    user                    User Name configuration for the USM security model
    view                    Define an SNMPv3 MIB view
    So is there a way to control my S1500 Switch via SNMP? Or what have i done wrong..
    Thanks!!
  • 2.  RE: Question: Is there a way to control the Aruba S1500 Switch via SNMP?
    Posted Feb 05, 2014 02:52 PM
    mhrdy,
    The Mobility Access Switches, like the Mobility Controllers do not support SNMP Write access.
    Best regards,
    Madani
  • 3.  RE: Question: Is there a way to control the Aruba S1500 Switch via SNMP?
    Posted Feb 05, 2014 02:55 PM
    This are bad news :(
    Does the S2500 or S3500 switch support SNMP Write Access ?
    Thanks a lot!
  • 4.  RE: Question: Is there a way to control the Aruba S1500 Switch via SNMP?
    Posted Feb 05, 2014 02:58 PM
    No Mobility Access Switch (S1500, S2500, S3500) supports SNMP Write and there are no plans to support it. Same is true of Mobility Controllers too.
    Best regards,
    Madani
  • 5.  RE: Question: Is there a way to control the Aruba S1500 Switch via SNMP?
    Posted Feb 05, 2014 05:15 PM
    Oh, that is remarkable. It is very common for switching vendors to support SNMP write. This can be very useful in use cases like:
    - Enable/disable a certain port via SNMP
    - Enable/disable PoE for a certain port via SNMP
