  • 1.  Question on co-channel interference with Aruba Central managed APs
    Posted Jun 12, 2024 03:01 PM
    Kind sirs,
    We have 100s of APs managed by Aruba Central typically located in small offices.
    There is a plan to add a secondary wireless service (Non-Aruba) as a backup network.
    Question - is there a way to mitigate co-channel interference automatically using Aruba Central.
    Can Aruba Central detect an RF issue and re-assign the AP to another channel automatically?
    I am still not sure of the type of additional wireless gear but wanted to check on the Aruba side first.
    Alex
  • 2.  RE: Question on co-channel interference with Aruba Central managed APs
    Posted Jun 12, 2024 08:06 PM
    yes thats what Aruba APs do, based on noise floor and interference (both WiFi and non-WiFi).
    I suggest to reconsider the approach of adding secondary APs, and focus on the outcome they are trying to achieve, perhaps there is a better way.
  • 3.  RE: Question on co-channel interference with Aruba Central managed APs
    Posted Jun 13, 2024 03:42 AM
    From an RF perspective adding a secondary WLAN system to the site is the worst solution.
    Not only do you have interference from 3rd party Wi-Fi systems, that you don't control, but you also add an interference source potentially directly next to the Aruba APs.
    I also recommend to look for other solution to address the problem you are trying to solve, e.g. clustering with small gateway to provide redundancy, or install more APs to take advantage of secondary coverage. Depending on the problem you want to solve with the backup system.
    If a backup system needs to exist, then try to separate the channels from both systems, so that both system won't use the same channels. This eliminates co-channel interference, at the cost of having fewer channel to be used. Aruba can do it, not sure about the backup system. Also it's dependent on the geography you are in, in terms of available channels.
    Every automatic channel assignment mechanism is reactive and connectivity problems will be one trigger to change the channel. the risk of having a poor user experience is high, when sharing channels on two systems.
    On top of that both systems will most likely detect the other system as rogue network and throw warnings ... which leads to ignoring those events and a real rogue may go undetected.
