Wired Intelligent Edge
Question re. IPTV, IGMP and freezing picture frequently
This thread has been viewed 30 times
  • 1.  Question re. IPTV, IGMP and freezing picture frequently
    Posted May 20, 2022 01:28 PM
    Hello All,
    We have IPTV network with smart hospitality TV, and Aruba 5400, Aruba 2920, 2530 for the switches.
    In my understanding the IGMP configuration has to be enabled in all IPTV VLAN switches (I am using vlan 9 for IPTV), in fact it does not work.
    So my configuration is as follow :
    From above, I have the IGMP enabled in the core switch (5400) and disabled in the edge switches (2930 and 2530), all is working. But now there is issue : picture is freezing frequently after sometime.
    If I have the the IGMP enabled in the core edges the the IPTV is not working.
    The IPTV vlan in core :
    VLAN ID : 9
    VLAN NAME : IPTV Vlan
    IGMP Enabled [No] : Yes
    Querier Allowed [Yes] : Yes
    IGMP Version [2] : 2
    Strict Mode : No
    Last Member Query Interval (Seconds) [1] : 1
    Querier Interval [125] : 125
    Query Max. Response Time (Seconds) [10] : 10
    Robustness Count [2] : 2
    Port Type | Port Mode Forced Fast Leave Fast Leave
    A1 1000T | Auto No Yes
    A2 1000T | Auto No Yes
    IPTV Vlan in Edge
    VLAN ID : 851
    VLAN Name : IPTV Vlan
    1 100/1000T | Auto No Yes
    2 100/1000T | Auto No Yes
    3 100/1000T | Auto No Yes
    4 100/1000T | Auto No Yes
    5 100/1000T | Auto No Yes
    Can someone check my config and give me some clue ?
    Sugeng Selamet
  • 2.  RE: Question re. IPTV, IGMP and freezing picture frequently
    Posted May 30, 2022 05:06 AM
    Hi Sugeng,
    Probably the multicast traffic is treated as broadcast for your edge switches and depends on the traffic generated you are facing this video problems.
    For me IGMP needs to be enabled on the edge switches as well (snooping). As you have your core switch next to the source (probably used for querier) you can try to disable it for your edge switches, if they have IP addresses in vlan9 (under vlan context "no ip igmp querier").
    Stanislav Naydenov
  • 3.  RE: Question re. IPTV, IGMP and freezing picture frequently
    Posted Jul 25, 2023 11:56 AM
    >> Hello, I do not understand on this, would you please to elaborate?
    Sorry my previous config was not correct, here is after correction:
    IPTV Vlan in Edge
    VLAN ID : 9
