Question regarding captive portal authentication.
  • 1.  Question regarding captive portal authentication.
    Posted Jul 26, 2013 04:14 AM
    Captive portal is working fine... I enabled the user as well as guest at L3 profile
    Although the registered user can provide username & password for authentication and this portal login are also for the guest authentication.
    My Question is, is there any option to configure the username and password for guest user portal login as well ???
  • 2.  RE: Question regarding captive portal authentication.
    Posted Jul 26, 2013 05:31 AM
    Under the authentication > Layer 3 auth > captive portal auth > <name of the captive portal you are using >
    Uncheck the guest login and leave user login
  • 3.  RE: Question regarding captive portal authentication.
    Posted Jul 26, 2013 05:56 AM
    I know that... after disabling the guest login.
    But Is there any other option for guest portal login insteas of email ?
  • 4.  RE: Question regarding captive portal authentication.
    Posted Jul 26, 2013 06:58 AM
  • 5.  RE: Question regarding captive portal authentication.
