Question Regarding Master/Local Upgrade to 8.2 with Migration Tool
  • 1.  Question Regarding Master/Local Upgrade to 8.2 with Migration Tool
    Posted Jul 24, 2019 02:36 PM
    Hello everyone,
    I am currently in the process of upgrading my master/local deployement and had some concerns with the migration tool. We currently have a main campus with two masters in production with three sites in local mode. I would prefer to migrate a single location first (instead of hard cutting the entire enviroment). A couple of these locations do not have full-time staff onsite to assist in the upgrade so I would not prefer a manual migration. My question is whether or not the migration tool will allow administrators to upgrade one site at a time. (I would only enter the master IP and a single local controller IP in the tool and select "No"  on the "Migrate Master" option).
    Any advice or knowledge is much appreciated.
  • 2.  RE: Question Regarding Master/Local Upgrade to 8.2 with Migration Tool
    Posted Jul 24, 2019 03:48 PM
    well it depend,
    the migration tool will help you to migrate your configuration from 6.5 to version 8. It will give you 2 different configuration migreated. Default-Local and default Global.....  default-local is proper to the controller, and default-global is like an global configuration you will pushed to all your controllers.....
    i recommend to do an clean-up after using the migration tool because you will have a lot of default configuration.
    On my last deployment, my client worked with an hybrid environment, mobility master with 1 controllers (version 8) and also 1 master with 2 local controllers (version 6.5)
  • 3.  RE: Question Regarding Master/Local Upgrade to 8.2 with Migration Tool
    Posted Jul 24, 2019 05:29 PM
    So were you able to migrate one location at a time in the Master/Local deployment in your case?
