Question regarding MIMO and client density
  • 1.  Question regarding MIMO and client density
    Posted Mar 28, 2015 03:30 PM
    I keep reading that in order to utilize a 3x3:3 AP, you would need a 3x3 client.
    What I'm trying to understand if this is a misconception. While I understand that throughput may be limited to 2 streams in a 2x2 client, couldn't a 3x3 configuration support more clients?
    I'm thinking something along the lines of the following
    Client 1 could utilize Tx radios 1, 2 and client 2 could utilize Tx radios 2 and 3.
    Can someone verify this is the case?
  • 2.  RE: Question regarding MIMO and client density
    Posted Mar 28, 2015 03:43 PM
    802.11ac Wave 2 will haver his functionality
    http://en.m.wikipedia.org/wiki/Multi-user_MIMO
