Question regarding rules
  • 1.  Question regarding rules
    Posted Aug 19, 2013 12:48 AM
    I want to know,  in the value portion , may i have to provide the mac address of the client here else i have to provide the mac address of the AP ?
  • 2.  RE: Question regarding rules
    Posted Aug 19, 2013 01:41 AM
    Yes, that should be BSSID of the AP and not the user.
    From user-guide:-
  • 3.  RE: Question regarding rules
    Posted Aug 19, 2013 01:52 AM
  • 4.  RE: Question regarding rules
    Posted Aug 19, 2013 05:22 AM
    What type of condition i have to select here ?
    there are many options related to the condition and wat is the purpose of all individuals ? What is the purpose of after selecting individuals ?
    Contians = prupose
    Ends-with =
    Equals =
    Not Equal =
    Starts-with =
    From user-guide:-
  • 5.  RE: Question regarding rules
    Posted Aug 19, 2013 07:19 AM
    For you case, you may need to  choose "contains" to put in the mac adress of the AP`s BSSID to take care.
    Here are the list of condition we have..
    The purpose of having this option is to optimize and for flexibility. Say for example " you have the specific list of device  "oui" wants them on specfic role; you  may needs to choose the conditions "starts with"  where all the devices ,matching  or starting with that specific OUI will be placed on the role appropriately. Similarly  if you want the exact match of mac address you may need to go for "equals". These options basilly gives us more customization to define the rules.
    (Aruba) (user-rule) #set role condition bssid ?
    contains  Check if attribute -contains- the operand value
    ends-with  Check if attribute -ends-with- the operand value
    equals     Check if attribute -equals- the operand value
    not-equals  Check if attribute -not-equals- the operand value
    starts-with  Check if attribute -starts-with- the operand value
    Thanks!
  • 6.  RE: Question regarding rules
    Posted Aug 19, 2013 08:41 AM
    One thing i want to understand, after selecting the "role"  then "BSSID"  then "condition" then  in the " value" portion whether we have to enter the MAC-address of the AP or something else...
    Too much confuse... kindly help me in this regard.
  • 7.  RE: Question regarding rules
    Posted Aug 19, 2013 08:46 AM
    That should be the AP`s one.
