last person joined: 11 hours ago
QUESTION WHEN INTRODUCING LICENSES MANUALLY IN AOS 8.6
  • 1.  QUESTION WHEN INTRODUCING LICENSES MANUALLY IN AOS 8.6
    Posted Jan 20, 2020 05:44 AM
    Hello.
    I want to configure a controller 7010 in standalone mode, with a very simple configuration. I have upgraded it to 8.6.0.2.
    I have introduced the licenses via GUI and via CLI.
    When I introduced them via GUI, when putting in the PEFNG, RFP, WebCC, I was asked to mark the option “1 xxx licenses are available in global license pool”. I am not asked in regards the AP licenses.
    On other side, when doing this via CLI, I get the next response: “Please make sure to enable the feature bit to have the license take effect”. I did not received such a response with AP license.
    Are both messages related with the same question?
    What are the consequences of marking, when introducing via GUI?
    What do I have to do when doing this via CLI?
    How can I “enable the feature bit to have the license take effect”?
    What are the consequences of enabling the feature bit to have the license take effect?
    Can a modify the selected option later? I have seen that when showing the licenses via GUI I can modify “Feature enable”.
    I attach to images GUI and CLI.
    Thanks for the responses.
  • 2.  RE: QUESTION WHEN INTRODUCING LICENSES MANUALLY IN AOS 8.6
    MVP EXPERT
    Posted Jan 20, 2020 06:03 AM
    Only AP licenses are enabled by default when those licenses are added to a constoller, All other licenses must be manually enabled.
    You can do this via the CLI or via the slider in the GUI.
    license-pool-profile-root
        pefng-licenses-enable
        rfp-license-enable
        acr-license-enable
    You can enable/disable the licenses later if required.
  • 3.  RE: QUESTION WHEN INTRODUCING LICENSES MANUALLY IN AOS 8.6
    Posted Jan 20, 2020 06:37 AM
    Thanks for your answer.
    In CLI mode, I get an error. It looks that such a commad only works in MM mode, and mime is standalone.
    No matter, I will enable licenses when I load then, using GUI or enable them in the GUI options, if I load via CLI.
    I attach the error.
    Regards.
  • 4.  RE: QUESTION WHEN INTRODUCING LICENSES MANUALLY IN AOS 8.6
    MVP EXPERT
    Posted Jan 20, 2020 06:39 AM
    Confusing I know, but you need to enable it at /mm on a Standalone.
    (Aruba7030) *[mynode] #show roleinfo
    switchrole:standalone
    (Aruba7030) *[mynode] #cd /mm (Aruba7030) *[mm] #configure t Enter Configuration commands, one per line. End with CNTL/Z (Aruba7030) *[mm] (config) #license-pool-profile-root (Aruba7030) *[mm] (License root(/) pool profile) #
  • 5.  RE: QUESTION WHEN INTRODUCING LICENSES MANUALLY IN AOS 8.6
    Posted Jan 20, 2020 06:48 AM
    Thanks you very mutch. I works. I did not know such questions.
  • 6.  RE: QUESTION WHEN INTRODUCING LICENSES MANUALLY IN AOS 8.6
    MVP EXPERT
    Posted Jan 20, 2020 06:49 AM
    Glad to hear it :)
