AP303HR is listed as a remote AP. Is it Unified?
Are the E1 E2 E3 interfaces configurable? If so how?
I want to use the AP303HR as a campus AP and utilize the 3 other
interface for separate vlans.
Yes, AP-303H(R) ships as a unified AP, and can be used with controller (AOS) or without (Instant). Port configuration is no different from any other AP with multiple ports.
Thanks Onno.
Can you steer me to the documentation for configuring multiple ports?
I cannot, but hoping someone else can.
These links should give you enough information to get going:
https://www.arubanetworks.com/techdocs/ArubaOS_80_Web_Help/Content/ArubaFrameStyles/1CommandList/ap_wired_port_profile.htm
Basically you create a wired port profile, and then apply them to the interfaces that you want it on. Try not to use Eth0 though, as this is sually your APs uplink port.
Attachment(s)
That works. All good, thanks!
