- Spectrum Load Balancing – We currently do not have this enabled, but it appears that this feature should be enabled. We currently have issues with too many people connecting to APs and ignoring others
If you have AOS 6.3 and up ClientMatch is enabled under ARM by the default and this will be managed by ClientMatch , the same goes for Band Steering
- In our 802.11a radio profile > General > Channel - there is a channel set to 52. Should that be set or should we be leaving that empty?
If you are not using DFS channels you can leave that option disabled
- One of our admins set a Min 2.4GHz power profile (to lower the power on 2.4GHz) but when I look at the Adaptive Radio Management (ARM) Profile the Max Tx EIRP is set to 127 (the absolute maximum) and the Min Tx EIRP is set to 9 (slightly higher than default)
If you have a very dense AP deployment you should consider setting that to 18/12 or even 12/6 (make sure you test this before making this adjustment because it could create coverage holes)
