Questions about IAP-205
  • 1.  Questions about IAP-205
    Posted Jan 04, 2018 11:55 AM
    I have deployed/admin a total of 4 IAP-205s.
    I now have to deploy APs that cost less for our lower end properties and they are telling me the APs use uplink/downlink to "mesh" the APs.
    Question:
    Are the IAP-205s using uplink/downlink or mesh? They are all wired into the switch. I want to make sure I am using the same technology as the IAP-205s even if I have to use a lower end brand.
  • 2.  RE: Questions about IAP-205
    Posted Jan 09, 2018 06:33 PM
    If they are all wired, they are not using mesh.
