Questions about show APs output for new network
  • 1.  Questions about show APs output for new network
    Posted Jan 24, 2013 10:17 AM
    I am Aruba newbie with newbie questions.  Have new instant network of 13 IAP-105's and have newbie questions on output from show APs command for my network.
    1)  Why are all AP's but one showing Mesh Role = Portal except one showing Mesh Role = Point?
    2)  Why are power settings for 5ghz radio power so low (9dB) for so many APs?
    3)  Why is Config From Port = Bond0 for some and Config From Port = None for others?
     1/24/2013 10:07:14 AM    Target: B4 Main Floor    Command: show aps
    AP List
    Name             IP Address    Mode    Spectrum  Clients  Type  Mesh Role  2.4 Channel  2.4 Power (dB)  2.4 Utilization (%)  2.4 Noise Floor (dBm)  5.0 Channel  5.0 Power (dB)  5.0 Utilization (%)  5.0 Noise Floor (dBm)  Need Antenna Config  From Port
    B4 Main Floor    10.10.253.22  access  disable   3        105   Portal     6            22              13(good)             -94(good)              44+          9               4(good)              -93(good)              No                   none
    B4 Basement      10.10.253.23  access  disable   2        105   Point      11           7               11(good)             -94(good)              44+          22              4(good)              -93(good)              No                   none
    B7 Break Rm      10.10.253.28  access  disable   3        105   Portal     1            17              34(good)             -95(good)              108+         22              3(good)              -93(good)              No                   bond0
    B7 Mez Upper     10.10.253.27  access  disable   4        105   Portal     11           17              34(good)             -96(good)              132+         22              1(good)              -93(good)              No                   bond0
    Pole Barn North  10.10.253.24  access  disable   0        105   Portal     6            22              10(good)             -94(good)              40-          9               2(good)              -91(good)              No                   bond0
    B5 Main Floor    10.10.253.21  access  disable   19       105   Portal     6            22              19(good)             -96(good)              36+          9               2(good)              -93(good)              No                   bond0
    Pole Barn South  10.10.253.35  access  disable   0        105   Portal     11           17              9(good)              -94(good)              108+         9               2(good)              -93(good)              No                   bond0
    B6 Main          10.10.253.25  access  disable   10       105   Portal     6            7               25(good)             -96(good)              108+         9               2(good)              -93(good)              No                   bond0
    B8 Shop          10.10.253.32  access  disable   3        105   Portal     11           17              24(good)             -94(good)              40-          9               2(good)              -93(good)              No                   bond0
    B7 Main Floor    10.10.253.29  access  disable   8        105   Portal     6            22              38(good)             -96(good)              44+          9               1(good)              -93(good)              No                   bond0
    B6 LAB           10.10.253.26  access  disable   7        105   Portal     11           17              32(good)             -94(good)              36+          9               1(good)              -93(good)              No                   none
    B8 Main Floor    10.10.253.34  access  disable   5        105   Portal     1            17              17(good)             -95(good)              108+         9               3(good)              -93(good)              No                   bond0
    B7X Main Floor   10.10.253.30  access  disable   6        105   Portal     1            17              37(good)             -94(good)              36+          9               2(good)              -93(good)              No                   bond0
  • 2.  RE: Questions about show APs output for new network
    Posted Jan 29, 2013 07:49 AM
    1) just guessing here, could it be the Point one is the virtual controller?
    2) might be that 9dB is just enough?
    3) not a clue
    in general might there a something in the IAP admin guide?
  • 3.  RE: Questions about show APs output for new network
    Posted Jan 29, 2013 01:24 PM
         The IAP with the valid uplink connection is the mesh portal. The mesh portal may also act as a Virtual Controller. The unwired
         IAPs are mesh points.
          This is taken care by ARM , Adaptive Radio Management dynamically and intelligently choosing the best 802.11 channel and transmit power for
           each Aruba AP in its current RF environment.
  • 4.  RE: Questions about show APs output for new network
    Posted Jan 29, 2013 01:36 PM
    Thank you.  The mystery is how did my instant AP-105 network think there was any "mesh" going on.
    Since posting this question I had a problem yesterday where my Instant network of fourteen IAP-105s kept rebooting itself.  Way scary.  I called tech support and the engineer saw the last AP attempting to boot was the same AP listed as "point" above.  He suggested I reset it, but I found it easier to replace.
    Now when I show APs I show mesh role  = portal and from port  = none.
  • 5.  RE: Questions about show APs output for new network
    Posted Jan 30, 2013 11:04 PM
     Instant AP(dual radio) will bring up as mesh point if the eth0 is down, but this ap should be sync configuration from the Cluster before.
  • 6.  RE: Questions about show APs output for new network
    Posted Jan 31, 2013 09:29 AM
    I recall that when I was testing my first two IAP-105s, I questioned based on the Instant User Guide whether they should support uplink.  I could not find an "eth1" port on the back and so tried enabling uplink on the AP and using the "console" port for the uplink.
    Of course it didn't work and my VAR Aruba SE responded to my question that the AP-105 does not support uplink and that the Instant User Guide does not make that excruciatingly explicit and clear.  APs with two ethernet ports are labeled "eth0" and "eth1".
    IAP-105 has two ports labeled "console" and "enet"
    I wonder if I had mistakently left uplink enabled on that AP if it would have showed as "point" and what other side effects that might have caused.
    The AP I would have done this with WAS the AP I just replaced when I had the network rebooting incident.
    Also, I would like answer on the "from port" = "bond0".  What does this mean?
    After replacing that AP, all show "mesh role" = "portal" and "from port" = "none".
    All fourteen of these APs are connected to switch on same layer 2 subnet and VLAN.
