Quick AP vs IAP Question
  • 1.  Quick AP vs IAP Question
    Posted Oct 17, 2018 10:43 AM
    I have a lot of IAP-205 running via AirWave. We just aquired a new company's wireless and they have all AP-105 running via standalone 3400 controller. My question is will the AP-105 work on AirWave like the IAP-205's? I would like to manage them from AirWave vs the 3400 controller.
  • 2.  RE: Quick AP vs IAP Question
    Posted Oct 17, 2018 10:50 AM
    Yep, you would add the controller to Airwave and manage the controller and APs via Airwave.
    *Be sure to import the config for the template to manage the controller. I forgot this once, will never do it again.
  • 3.  RE: Quick AP vs IAP Question
    Posted Oct 17, 2018 11:43 AM
    EDIT: didnt see the other reply before i posted the below response. thanks for the imformation from both of you.
    if i dont want to use the controller and just add the Ap-105s to AirWave will that work?
  • 4.  RE: Quick AP vs IAP Question
    Posted Oct 17, 2018 01:00 PM
    Are those IAPs or Aps? You can take a look at the back of the AP
    Sent from Mail for Windows 10
  • 5.  RE: Quick AP vs IAP Question
    Posted Oct 17, 2018 01:02 PM
    i believe they are AP's and not IAPs. how can i tell via the 3400 controlller.
  • 6.  RE: Quick AP vs IAP Question
    Posted Oct 17, 2018 11:03 AM
    I recommend you continue managing your AP-105s via the 3400 controller but you can manage those via AirWave
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
