Quick Reference for AP PoE Requirements
This thread has been viewed 31 times
  • 1.  Quick Reference for AP PoE Requirements
    Posted Jul 02, 2024 07:16 PM
    Edited by jpb Aug 01, 2024 11:43 AM
      730 650 630 615 555 535 515 505
    Eth interfaces 2x5G 2x5G 2x2.5G 1x2.5G 2x5G 2x5G 1x2.5G, 1x1G 1x1G
    802.3af support
    2 Ports & IPM enabled*
      IPM       IPM
    802.3at Class 4 (30W) support IPM IPM IPM X IPM IPM X X
    802.3bt Class 6 (60W) or higher preferred (no IPM, no restrictions) X X X   X X
    When PoE power is supplied to both Ethernet ports, power from both interfaces is combined    X     X X
    When PoE power is supplied to both Ethernet ports, either port can be configured as the active power source Active/Standby X   X
    Only Eth0 supports POE       X     X X
    When powered by 802.3at (class 4) PoE with the IPM feature disabled, the AP will disable:
    USB ports
    2nd Ethernet
    2x2 all radios
    4x4 only 5G radio
    Disable tri-radio
    USB
    • USB*
    • 2nd Eth
    • 2x2 All Radios*
    USB USB
    • USB
    • 2nd Eth
    • 4x4 (5G)
    • Disable tri-radio
    • USB
    • 2nd Eth
      USB
    Attachment(s)
    xlsx
    AP Power Requirements.xlsx   10 KB 1 version
