Quick Salesy 101/Competitve; Instant WAP vs Meraki MR WAP
  • 1.  Quick Salesy 101/Competitve; Instant WAP vs Meraki MR WAP
    Posted Nov 08, 2017 08:55 AM
    As per subject.
    Has the field got anything to help me try to combat Meraki MR WAPs vs an Aruba Instant WAP choice and it's AOS.
  • 2.  RE: Quick Salesy 101/Competitve; Instant WAP vs Meraki MR WAP
    Posted Nov 14, 2017 08:09 AM
    Please work with your local Aruba sales team to get topics like these covered. If you are an Aruba partner, you can check the Partner Ready for Networking portal or Arubapedia for partners.
  • 3.  RE: Quick Salesy 101/Competitve; Instant WAP vs Meraki MR WAP
    Posted Nov 14, 2017 09:45 AM
    I'm a partner..
    And FYI..
    https://imgur.com/a/cBdw7
    And that URL redirects to….
    https://psnow.ext.hpe.com/partner/doc?id=4aa6-8356enw.pdf
    Which is not a PDF/does not render a PDF/missing document.
    It goes to https://psnow.ext.hpe.com/#/dashboard
    Where there is no presence of the aforementioned pdf..
    https://imgur.com/a/4dobw
  • 4.  RE: Quick Salesy 101/Competitve; Instant WAP vs Meraki MR WAP
    Posted Nov 14, 2017 10:12 AM
    I can't access that portal myself, but you should have access to https://partner.hpe.com/group/upp-aruba/arubapedia to go to Arubapedia for Partners once you logged in.There, on Arubapedia, search for your battle card. Please work with your local Aruba sales team to help you in this case.
  • 5.  RE: Quick Salesy 101/Competitve; Instant WAP vs Meraki MR WAP
    Posted Nov 14, 2017 10:33 AM
    That's better...... Thankyou. ! :)
