Quick walk through
  • 1.  Quick walk through
    Posted Apr 23, 2016 03:33 PM
    I have 2 instant access points, i would like to have the second one mesh up but not re-broadcast the ssid, i want to use it as a bridge and use its ethernet ports (its a 205H) to connect a hardlined machine.
    could someone give me a quick walk through?
    thanks!
    #AirheadsMobile
    #ALE
  • 2.  RE: Quick walk through
    Posted Apr 23, 2016 03:45 PM
    Maybe this might work if you create different zones and only send out the ssid in one zone and use the mesh in instant. But I have not yet build this setup
  • 3.  RE: Quick walk through
    Posted Apr 24, 2016 06:26 AM
    You will need to broadcast at least one SSID on a Instant Mesh AP, as the AP will consider itself unconfigured as it sees no SSID configured and wipe the config.
    See: http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Instant-27x-AP-with-Ethernet-Bridging/m-p/262940 for a similar question.
