Quickconnect and Samsung S5 fingerprint scanner
  • 1.  Quickconnect and Samsung S5 fingerprint scanner
    Posted Aug 05, 2014 10:47 PM
    We've noticed the quickconnect seems to be incompatible with the new S5.
    Fingerprint scanning is not recognised as a secure login method and it won't allow onboard credentials to be stored if this is set.
    If you temporarily set PIN as a login method, you are unable to change back to a fingerprint login - the option is greyed out.
    Seems to be quickconnect is not recognising the new method. Anyone else had this problem and can we expect an update soon?
  • 2.  RE: Quickconnect and Samsung S5 fingerprint scanner
    Posted Aug 05, 2014 10:49 PM
    I’ve noticed on Samsung Android devices, it always requires a PIN to be set even though there is nothing in the configuration profile that says it should.
    I’m guessing we’re seeing the same issue.
  • 3.  RE: Quickconnect and Samsung S5 fingerprint scanner
    Posted Aug 05, 2014 10:51 PM
    Yep, sounds right.
    Unfortunately all my clients are quite taken with their new fingerprint scanners and "won't use onboard" if be can't supported. Do you think this can be resosved by a quickconnect update or is it just a samsung issue?
  • 4.  RE: Quickconnect and Samsung S5 fingerprint scanner
    Posted Aug 05, 2014 10:52 PM
    Seems to be only affecting Samsung. Definitely worth having Aruba TAC investigate though.
  • 5.  RE: Quickconnect and Samsung S5 fingerprint scanner
    Posted Aug 05, 2014 10:53 PM
    I'm TACing away now
  • 6.  RE: Quickconnect and Samsung S5 fingerprint scanner
    Posted Aug 05, 2014 10:58 PM
    cappalli, have you noticed whether the samsung 'password' login method is accepted by quick connect?
    This is listed as 'high security' in the S5 interface, whereas pin is listed as 'medium to high security'
