Wired Intelligent Edge
Quickly convert instants to campus APs?
  • 1.  Quickly convert instants to campus APs?
    Posted Aug 13, 2019 05:21 AM
    I have a somewhat-large quantity of AP-303H's that I'd like to provision as Campus APs associated with our 7220 controllers.
    Is there a way to do this without manually connecting to the SetMeUp SSID and converting each and every one? Like a DHCP option perhaps?
    Thanks!
  • 2.  RE: Quickly convert instants to campus APs?
    Posted Aug 13, 2019 05:38 AM
    You can try:
    Plugging them all in at the same time so they form an Instant Cluster.
    Use the convert option to convert the entire cluster by pointing them at the controller..
  • 3.  RE: Quickly convert instants to campus APs?
    Posted Aug 13, 2019 07:07 PM
    Aruba will tell you not to put so many in a cluster - but I was just clustering in order to convert them all. Was able to convert 146 at a time.
  • 4.  RE: Quickly convert instants to campus APs?
    Posted Aug 14, 2019 05:18 AM
    Thank you both - this is the way I've proceeded and it seems to be working well.
