quoting AP 274 question
  • 1.  quoting AP 274 question
    Posted May 14, 2015 11:48 PM
    Hello
    I would like to know  what is this
    What is this cable ? i would like to know what do you use that for.  Are this cables to connect the AP with the Antenna?
    For the Antenna i got these options, it says the antenna is dual band
    and there is another option for 2.4ghz
    Dont you just pick one as the antenna is dual band??  or you have to pick one ANT 3x3-D100 for each radio?
    At the end i end for one AP what should i have?
    2x ANT-3x3-D100?
    or
    1xANT-3x3-D100??
    And also how many  RF cables should i have?
    Im confused... anyone can help????
    Cheers
    Carlos
  • 2.  RE: quoting AP 274 question
    Posted May 14, 2015 11:58 PM
    What kind of coverage are you looking for? Directional? Omni?
    Where will the antennas be mounted?
    Tim
  • 3.  RE: quoting AP 274 question
    Posted May 15, 2015 12:02 AM
    HEllo Tim
    The antenna i was looking was that one you see i picked a semidirectional antenna which is a 90 degrees antenna.
    I need a really good coverage for pdts at 100 meters
    the Antennas can be mounted in a wall  or also on a building which is next to it
  • 4.  RE: quoting AP 274 question
    Posted May 15, 2015 12:04 AM
    Have you considered the AP-277? Directional, no external antennas needed.
    Tim
  • 5.  RE: quoting AP 274 question
    Posted May 15, 2015 12:21 AM
    Yes but i need it to be instant AP
    I cannot see it on the price list!
