Rad sec certificate
  • 1.  Rad sec certificate
    Posted Jul 07, 2019 09:56 AM
    How do i find about radsec certificate in my network because i think my network does not have radsec
  • 2.  RE: Rad sec certificate
    Posted Jul 07, 2019 10:32 AM
    For which product?
  • 3.  RE: Rad sec certificate
    Posted Jul 07, 2019 11:25 AM
    I am getting radsec certificate is expiring for iap's
  • 4.  RE: Rad sec certificate
    Posted Jul 07, 2019 01:31 PM
    Please paste a screenshot of the message here.  Are you using Aruba Central?
  • 5.  RE: Rad sec certificate
    Posted Jul 09, 2019 02:13 AM
    Cert Expiring Description: The certificate for this device is set to expire [date]. Please update certificate on this asset to prevent reachability issue with this asset is error message what i see via CLI.
    As u guessed it right i am using aruba central
  • 6.  RE: Rad sec certificate
    Posted Jul 22, 2019 04:39 AM
    any luck on the solution?
  • 7.  RE: Rad sec certificate
    Posted Jul 22, 2019 06:00 AM
    Where are you seeing this message?  What command did you run?  Can we see the exact command you used and thr resulting message, please?
  • 8.  RE: Rad sec certificate
    Posted Jul 22, 2019 08:18 AM
    Hi Joseph,
    Thanks for your reply,i am getting tickets generated in sfdc via netcool monitoring tool with the subject line as "Cert Expiring Description: The certificate for this device is set to expire (date). Please update certificate on this asset to prevent reachability issue with this asset"
  • 9.  RE: Rad sec certificate
    Posted Jul 10, 2019 09:06 AM
    "Cert Expiring Description: The certificate for this device is set to expire [date]. Please update certificate on this asset to prevent reachability issue with this asset" is error message what i see via CLI.
