Radio won't enable
  • 1.  Radio won't enable
    Posted May 03, 2022 03:45 PM
    We try to use 5GHz band and radio, however, state is staying in disable mode.
    In CLI,
    (controleur-1) *[mm] (config) #rf dot11a-radio-profile "default"
    (controleur-1) *[mm] (802.11a radio profile "default") #radio-enable
    (controleur-1) ^*[mm] (802.11a radio profile "default") #show rf dot11a-radio-profile "default"
    Parameter Value
    Radio enable Disabled
    Mode ap-mode
    AM tx mute (radio) Disabled
    High throughput enable (radio) Enabled
    Very high throughput enable (radio) Enabled
    High efficiency enable (radio) Enabled
    Channel N/A
    Transmit EIRP 15.0 dBm
    What could we do ?
    BILLOT Emmanuel
  • 2.  RE: Radio won't enable
    MVP GURU
    Posted May 03, 2022 03:51 PM
    Did you perform a "write mem" before running the show command? If not, try that and then see if the show command shows enabled.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Radio won't enable
    Posted May 03, 2022 04:47 PM
    I finally found : 5GHz was unchecked in node context, blocking activation in MM context.
    BILLOT Emmanuel
