RADIOUS source interface in AOS8
This thread has been viewed 22 times
  • 1.  RADIOUS source interface in AOS8
    Posted Nov 19, 2020 08:13 AM
    I am in the process of migrating from AOS6 to AOS8.7.
    In AOS6 I could set RADIUS source interface per RADIUS server.
    In AOS8 it seems that this option is removed? I can set RADIUS client source under Configuration > Authentication > Advanced, but that will apply to all RADIUS servers.
    I have multiple RADIUS-servers on different networks so I need to be able to set source per server. Is there a new way to do this?
    Regards
    Philip
    Philip Vilhelmsson
  • 2.  RE: RADIOUS source interface in AOS8
    Posted Nov 19, 2020 09:18 AM
    Still there
    You can also use the command :
    ip radius source-interface vlan <VLAN-ID>
    Victor Fabian, ACEX#8
    Mobility Architect @ WEI
  • 3.  RE: RADIOUS source interface in AOS8
    Posted Nov 19, 2020 09:27 AM
    Yes, the global setting is there, but not the one per server.
    I can not see the same setting in AOS8.
    Philip Vilhelmsson
  • 4.  RE: RADIOUS source interface in AOS8
    Posted Nov 19, 2020 09:34 AM
    Ahh yeah unfortunately is not via the GUI, but it is available via CLI
    (MM-1) [WEI] (RADIUS Server "CPPM-RADIUS-SVR-1") # source-interface vlan <VLAN-ID>
  • 5.  RE: RADIOUS source interface in AOS8
    Posted Nov 19, 2020 09:54 AM
    Yay! Thanks!
    Philip Vilhelmsson
