Radius accounting anomolies
  • 1.  Radius accounting anomolies
    Posted Mar 03, 2014 06:02 AM
    Hi there,
    We have setup accounting to track usage etc of our clients, but I am not convinced it is working correctly.
    The reason I say this, is that if I log off and on again a few times, not all the logins are sent to the accounting - we don't see all the Accounting-Request Start and Stop entries, the number of misses is random.
    We also want the interim accounting info, so have ticked that box as well, but I am not sure what interval we should be seeing, should this be regular or random?
    An example of what we are seeing relating to the random interim-update is below.
    Tue Feb 25 09:00:07 2014
            NAS-IP-Address = 10.62.20.65
            User-Name = "A#####"
            Acct-Session-Id = "A#####5CD998A364AB-B1"
            Acct-Status-Type = Start
            Packet-Src-Port = 1814
             Service = "WA"
             Client = "XXX"
             HUB = "123 ABC"
            Timestamp = 1393318807
    Tue Feb 25 09:08:27 2014
            Acct-Status-Type = Interim-Update
            Acct-Input-Octets = 37778
            Acct-Output-Octets = 36549
            Acct-Input-Packets = 457
            Acct-Output-Packets = 73
            Acct-Session-Time = 501
                Service = "WA"
             Client = "XXX"
             HUB = "123 ABC"
          Timestamp = 1393319307
    Tue Feb 25 09:17:10 2014
            Acct-Session-Id = "A#####5CD998A364AB-B2"
          Service = "WA"
             Client = "XXX"
             HUB = "123 ABC"
            Timestamp = 1393319830
    Tue Feb 25 09:19:47 2014
            Acct-Input-Octets = 7039
            Acct-Output-Octets = 1031
            Acct-Input-Packets = 92
            Acct-Output-Packets = 5
            Acct-Session-Time = 157
          Service = "WA"
             Client = "XXX"
             HUB = "123 ABC"
            Timestamp = 1393319987
    Tue Feb 25 10:35:03 2014
            User-Name = "B#####"
            Acct-Session-Id = "B#####5CD998A364AB-BA"
          Service = "WA"
             Client = "XXX"
             HUB = "123 ABC"
            Timestamp = 1393324503
    Tue Feb 25 10:41:01 2014
            Acct-Session-Id = "B#####"
            Acct-Input-Octets = 93307
            Acct-Output-Octets = 731885
            Acct-Input-Packets = 884
            Acct-Output-Packets = 789
            Acct-Session-Time = 358
          Service = "WA"
             Client = "XXX"
             HUB = "123 ABC"
            Timestamp = 1393324861
  • 2.  RE: Radius accounting anomolies
    Posted Mar 03, 2014 06:56 AM
    awightman, what sort of server are you using for accounting, is it Clearpass or another?  Is this a controller based or Instant based wlan?
    The interim accounting interval default, and max is 10 mins.  You can change this value in the aaa-timers.
    aaa timers stats-timeout 300 seconds
  • 3.  RE: Radius accounting anomolies
    Posted Mar 03, 2014 07:05 AM
    Hi Mike,
    We are using free-radius not Clearpass, it's a controller-based solution.
    We havent adjusted the timers but if you see the interim-updates in the info, you will see that is varies for 8 minutes in one, then 6 minutes in another.
    More concerning is the lack of start-stop packets for some of the connections I made though.
    Cheers
    Andrew
  • 4.  RE: Radius accounting anomolies
    Posted Mar 03, 2014 07:23 AM
    I'd probably start with a radius capture on the controller to see if that matches what you see in the logs there.
    v 6.3 - packet-capture controlpath udp 1613
    pre 6.3 - packet-capture udp 1613
    Captured packets are stored in /var/log/oslog/filter.pcap within the logs.
    I've not had to deal a lot with accounting, but if you're not seeing what you expect, that may be one for TAC to take a look at.
  • 5.  RE: Radius accounting anomolies
    Posted Jun 04, 2014 10:02 AM
    Hi Mike,
    My situation has got even worse now!!!
    On another airport I have configured MAC auth (guess the application ;-)), and I get NO accounting packets at all.
    Does Aruba acrtually do accounting - seems pretty hit and miss to be honest.
    Hopefully Aruba step in and tell me that I missed a checkbox or something but pretty sure the config is all good.
    The users get authenticated OK, the accounting server is defined in the profile (same as the auth server), and Interim accounting box is also checked for good measure!!
    Cheers
    Andrew
  • 6.  RE: Radius accounting anomolies
    Posted Jun 04, 2014 10:48 AM
    1.  Make sure you have the right server configured in the radius accounting profile in the AAA profile.
    2.  Radius accounting is only sent to the first server in the server group.
    3.  Radius accounting stop is generated when the user is aged out of the user table, NOT when they disconnect.
    4.  Maybe you should open a support case so that you can get all of your questions answered.
  • 7.  RE: Radius accounting anomolies
    Posted Jun 04, 2014 11:05 AM
    I only have one server in the server group, and this is the server in the accounting profile as well, so can't understand why it's not working.
    Cheers
  • 8.  RE: Radius accounting anomolies
    Posted Jun 04, 2014 10:56 AM
    Hi Andrew,
    What port is your radius server configured for accounting?  Make sure this matches in your Aruba radius server config.  Sometimes, they use port 1646 instead of 1813.
    Did you manage to get a radius capture on the controller to check if the accounting messages are being generated?
  • 9.  RE: Radius accounting anomolies
    Posted Jun 04, 2014 11:07 AM
    Hi Mike,
    We allow both radius ports old and new through the firewall, but no packets even hit the next hop device, so looks like they are not being generated at all..
    Cheers
  • 10.  RE: Radius accounting anomolies
    Posted Jun 11, 2014 04:05 AM
    awightman have you opened a TAC ticket? they are setup to actually test this and confirm / deny your observations and hopefully solve your issue.
  • 11.  RE: Radius accounting anomolies
    Posted Apr 29, 2015 08:29 AM
    Hi all, was this resolved - what was the fix please?
  • 12.  RE: Radius accounting anomolies
    Posted May 01, 2015 11:15 PM
    In follow-up genuininely interested to know how the Aruba should behave in this regard compared with other offerings...
    https://community.aerohive.com/aerohive/topics/use_the_framed_ip_address_avp_containing_a_clients_ip_address_correctly_in_radius_accounting
