Hello everyone,
I have a concern regarding the 8325 aruba switch since I want to integrate a tacacs to make a centralize user management with CPPM. the tacacs perfectly works on 6300M access switches where user from cppm local db are able to authenticate using there credentials if they are authorized to access the devices. for aruba 8325 switch I need to configure a tacacs server but before I perfrom the aaa authorization login ssh tacacs local I need first to verify the radius server connectivity from 8325 switch to cppm but here is what I've encountered.
Troubleshooting:
Did you try to ping the cppm management IP from aruba 8325 switch ? yes, I was able to ping the cppm management IP
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/19f058a5af3943b6873acb8047bf02d1.png)
What AOS-CX version you have in 8325 switch ?
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/a8fc0314c44d4077b9d14640d071f1d1.png)
Please show if the radius and tacacs tracking are enable in 8325 switch ?
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/598eeda304164a7bb39991b03704c483.png)
Please show the radius server detail to verify the connectivity ?
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/3245e87c02a246768836e84128a49353.png)
Please show tacacs server detail to verify the connectivity
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/8a149260782d4335a8ee01573ee54cce.png)
