Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
  • 1.  Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
    Posted May 22, 2018 10:48 PM
    Hello. I'd like to ask for a guidance one more time.
    My goal is to start working with Clearpass, and i'm trying to bring simple lab. I have Win2016server, with AD working fine, CPPM 6.7, IAP305 latest, win7 as wifi client.
    The task is - on the CPPM catch up users, who are member of Grupe1, attach them a role, by that role "enforce" them to be assigned a role on IAP with simple deny icmp any any (further - denyping).
    The problem is that i don't even see CPPM passing the attribute Aruba-User-Role to IAP on the packet capture and the IAP is not catching it up also.
    Here is the setup:
    192.168.200.222 - CPPM, 192.168.100.20 - IAP
     As you can see policy is UserIsGrupe1
     Nevermind the condition, pl_test (my role) is the default role - and it is working. (see below)
    Here is the enforcement profile:clearpass04.png
    ... and the Attribute i'd like IAP to receive.
    The Enforcemenet policy
     Again, the condition might not work (thus it probably works) - but the Default Profile should work anyway.
    And what i see on the packet capture:clearpass05.pngAs you can see Accept-Accept, but there is no Aruba's vendor attribute. And IAP also don't see it.
    Here is output from tracker:clearpass11.png
    And here is the Ouput:
    Please, note - the Attribute is present, but it is not noticed on the packet capture, neither IAP recognizes it.
    Here is just in case config from IAP:
    All users fallback into ArubaRadio1 instead of denyping.
    I understand that there is stupid-little-something that i'm missing for a such trivial case, but i can't catch it.
    I'd really appretiate any advice. Thank you!
  • 2.  RE: Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
    Posted May 22, 2018 10:51 PM
    Do you have the role defined on the IAP?
  • 3.  RE: Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
    Posted May 22, 2018 10:57 PM
    I think i'm.
    Please also find attached CPPM log and packet capture files (just in case..)
    Thank you!
    Attachment(s)
    txt
    clearpass-pcap.log.txt   8 KB 1 version
    txt
    clearpass.log.txt   15 KB 1 version
  • 4.  RE: Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
    Posted May 22, 2018 10:56 PM
    1. In your enforcement profile, remove the device group requirement.
    2.The "Aruba-User-Role" VSA does not require a role assignment rule on the IAP. The IAP sees that attribute and changes the user role
    3.  I don't see "denyping" as a defined role on the IAP.  If the role you return with the VSA does not exist, the user just gets the default role.
  • 5.  RE: Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
    Posted May 22, 2018 11:01 PM
    Thank you cjoseph. But no luck - nothing has changed (after device removal)
    And regarding the role assignment on IAP - i've tried both ways, just the pointing manually with access rule seemed as a required prerequisite. But it should work anyway i think. And it isn't.
  • 6.  RE: Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
    Posted May 24, 2018 08:30 AM
    Try to disable Monitor Mode in your service. The screenshot shows it is enabled.
    Monitor Mode will return just an Access Accept, regardless policy/authentication, and is intended to see what would happen without actually doing it. From your description, this matches what you see.
  • 7.  RE: Radius Attribute from CPPM is not observed on IAP, but it seems to be sent
    Posted May 24, 2018 08:55 AM
    That is exactly what is was.
    Thank you very much! I can continue now :)
