Radius authentication
  • 1.  Radius authentication
    Posted Oct 28, 2014 07:23 AM
    Hi all
    Is it possible to create a WLAN profile that uses :
    1. authentication against a radius internal in the controller : user only connects with a username and password.
    2. mac authentication - I know this part...
    3. Certificates on the client side..
    Thanks for the help
  • 2.  RE: Radius authentication
    Posted Oct 28, 2014 07:34 AM
    Hi
    I was able to configure a WLAN profile  with mac-auth and 802.1x ( users go check internal database from aruba to connect).
    I have just one problem that is clients on PC´s that don´t have CA , do not connect.
    It goes OK with iphones and androids, but with a linux PC with asks for a CA that i don´t have.
    IS it possible to import some certificate from aruba to PC´s ? Because I see that Iphone gets an ssl certificate from aruba when it connects
    Regards
  • 3.  RE: Radius authentication
    Posted Oct 31, 2014 12:05 AM
    Beconnect,
    The certificate that you see in the controller is a built-in certificate that everyone should replace.  You are probably using termination for 802.1x which utilizes the built in certificate for the server certificate.  To obtain the CA certificate to put on your linux machine, you need a windows computer to log into the controller's GUI and save the certificate to a file.  I do not know the format your linux computer needs for that certificate, but below is an one way to extract it via Windows:
  • 4.  RE: Radius authentication
    Posted Oct 31, 2014 06:04 AM
    i cjoseph
    thanks
    I was able to login under linux, by changing the wlan settings on PC to PEAP.
    IS it possible now to change the auth from user / pass to certificates?
    Like , a user logins to wlan , but with a certifcate issued by the network ( a CA that the client has )?
    Regards
  • 5.  RE: Radius authentication
    Posted Oct 31, 2014 06:16 AM
    beconnect,
    EAP-TLS is a complicated thing to setup, and even harder under Linux.  Do you have a certificate authority?
