RADIUS authentication attempt from unknown NAD
This thread has been viewed 16 times
  • 1.  RADIUS authentication attempt from unknown NAD
    Posted Aug 01, 2019 02:11 AM
    I'm trying to test mac based authentication with my 2930f and clearpass and I simply cannot get the switch to authenticate via radius.
    In the event viewer, I have lots of "RADIUS authentication attempt from unknown NAD x.x.x.x:1812 (where x.x.x.x is the ip address of the switch) as soon I plug a phone into port 1.
    I have double checked the key on the switch, as well as the radius shared-secret on the device and they are _identical_.
    snippet from switch;
    aaa server-group radius "Clearpass" host 1.1.1.3
    aaa accounting update periodic 5
    aaa accounting network start-stop radius server-group "Clearpass"
    aaa authentication port-access eap-radius server-group "Clearpass"
    aaa authentication mac-based chap-radius server-group "Clearpass"
    aaa port-access authenticator 1
    aaa port-access authenticator 1 tx-period 10
    aaa port-access authenticator 1 supplicant-timeout 10
    aaa port-access authenticator 1 client-limit 3
    aaa port-access authenticator active
    aaa port-access mac-based 1
    aaa port-access mac-based 1 addr-limit 2
    The clearpass service i'm testing against is type radius, mac authentication template - authentication methos all MAC AUTH.
  • 2.  RE: RADIUS authentication attempt from unknown NAD
    Posted Aug 01, 2019 02:35 AM
    you may need to add your switch as Device to Clearpass and configure the secret, etc accordingly
  • 3.  RE: RADIUS authentication attempt from unknown NAD
    Posted Aug 01, 2019 02:37 AM
    Hi Martin,
     I've double checked. The radius key on the switch and the radius shared-secret on the device in clearpass is identical :(
  • 4.  RE: RADIUS authentication attempt from unknown NAD
    Posted Aug 01, 2019 02:45 AM
    unknown NAD normally means Clearpass is not aware of the switch or AP. Maybe wrong IP of the Switch in the Device config  in Clearpass?
  • 5.  RE: RADIUS authentication attempt from unknown NAD
    Posted Mar 19, 2020 04:54 AM
    Is the issue fixed?
    If yes, let me know how it got resolved.
