3: I think this is a nice write-up:
https://www.flomain.de/2016/12/aruba-instant-with-external-captive-portal/ with the exception that you need to install an SSL server certificate on your Instant AP in order to fix the certificate warnings. If you have Aruba Central management, you can use the aruba_default certificate from there, otherwise you need to install your own certificate. If you have Aruba Central management, there is Cloud Guest in there as well, and you could use that as well.
1&2: Yes, create an account in the Instant local users with a username and password of your choice and the type of Guest.
You will need to change the URL from
https://securelogin.arubanetworks.com/cgi-bin/login to your own domain that you requested the certificate on, like
https://guest.your-own-domain.tld/cgi-bin/login------------------------------
Original Message:
Sent: Nov 07, 2021 12:21 PM
Subject: Radius authentication request from External Captive Portal
Hi, Im totally newby and Im having some problems trying to authenticate an user from External Captive Portal using the internal Radius.
The goal is to let the user use the wifi after pressing a button on my external captive portal page.
First of all, I have no idea what Im doing, but some threads on this community brought me here.
<form method="post" ACTION="https://securelogin.arubanetworks.com/cgi-bin/login">
<input type="hidden" name="user" value="">
<input type="hidden" name="password" value="">
<input type="hidden" name="cmd" value="authenticate">
<input id="device_mac" type="hidden" name="mac" value="4e:a3:31:c1:b8:3a">
<input id="ap_mac" type="hidden" name="apmac" value="b8:3a:5a:5a:63:5a">
<input id="ip_address" type="hidden" name="ip" value="">
<input type="hidden" name="url" value="http://captive.apple.com/hotspot-detect.html">
<button class="button" type="submit">Continue</button>
</form>
My questions are:
1 - Whats the default user and password set, that I can use here? (InternalRadius)
2 - Is it possible to add a different user/password? How to do this from CLI?
3 - Is there some tutorials covering this topic? I could not find.
Thanks in advance
Thiago Matsuno
