I ahve Aruba 7200 controller and AP175.I want to authenticate user using active directory.User should not be authenticated certificate based.I want to use server 2008 as the radius server.What shall I do
Not sure if you are trying to configure Layer 2 authentication 802.1x authentication. If you just want to use username /password for user authentication and just the server validation however no certiticate check on client. you can choose the eap-type as eap-peap/mscahpv2.
The below link should help you to configure on controller.
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-202
Thank you.
Dear Sir,
Thanks for your reply.Let me just summarize.Inorder to authenticate user using active directory and without installing certificate on clients computer we will use either EAP-PEAP or MSCHAP-V2.We will use Windows NPS ,is it okay.
Regards
